Paollo
Treść opublikowana przez Paollo
Paollo odpowiedział(a) na Sterydziak temat w Kotły pelletowe
kto chce udostępnić mi Videnet Igneo.pl jako obserwatora? mój nick: paollo W końcu znalazłem najlepsze ustawienia dla mojego domu z pompą CO: TAK Z pomocą kolegów z forum Ozi80 i Robert004. Dziękuję Ci! -
The boiler was with automatic mode and central heating permanent pump = YES. And the heatig curbe was to high. Now it works much better with this: Boiler manual mode, preset = 67 Min Pump temperature = 46 Histerezis = 14 Central heating permanent pump = YES Histerezis 0,1 Weather curve 50 45 42 Burner default, except min air wich I increased a bit from 30 to 34 -
Gentlemen what settings you currently have? Those of you with 4d valve and permanent pump especially. boiler: mode = automatic hysteresis = 0 MIN pump temp = 49 degrees Central heating: Central heating manual set temperature senzor = 49 degrees Mode = manual (I disable the wheater mode wich only complicated things) correction factor = 15 degrees permanent pump = YES Burner: Feeding = 3.1s min air = 36 max air = 52 FL1 = 50 FL2 = 100 It works well but I do not know how to make the FL modulation work better. The problem is this. Burner starts with 50% power, then 55% then 60% then 80% then 100% for a lot of time it is 100% then it reaches the boiler set temperature(calculated between 50-70) + 5 degrees then turns off (without reaching the room set temperature). So it can not modulate in decreasing at the end. -
Czy można korzystać z trybu automatycznego pieczenia + stałej pompy CO? -
You mean central heating CO permanent pump? My service supplier said to disable the permanent pump CO and put the boiler in auto mode wich I did. Anyone with videnet willing to add me as an observer please? -
Exactly... I have videnet. Maybe someone willing to temporary give me access so i can see a good setup of tekla draco bio with 4d valve? Or others see my videnet. -
Zimno jak 50. Naprawiono pompę tak. Moje problemy pojawiły się, gdy starałem się utrzymać kontrolę nad przegrzaniem poprzez ograniczenie administracji. -
tak, duże różnice, 23 i 20, a także zmniejszyłem administrację wczoraj z 3,0 do 2,4, aby zapobiec przegrzaniu o +85 stopni, gdy nie ma zapotrzebowania na ciepło, ale kocioł i tak startuje. jeszcze jedno, nie mogę uzyskać tego kształtu litery V na wykresie videnet. na początku włącza pompę, jak powiedziałem, i utrzymuje kocioł na 55 59 stopni, a kiedy osiąga w końcu 68 stopni, utrzymuje go 70 przez długi czas. może moje pytanie powinno brzmieć: jaki jest idealny scenariusz i co powinienem spróbować osiągnąć? kocioł, który zaczyna się nie często i pracuje z pełną mocą, prawda? -
Jak mogę zapobiec włączaniu i wyłączaniu pompy CO podczas porannego zimnego startu? piec działa 2 lub 3 godziny bez możliwości przekroczenia temperatury początkowej pompy. działa cały czas na poziomie 100% lub 11kW, z wyjątkiem krótkiego czasu na początku i na końcu. czy to normalne? Boiler: set temperature = 68 Min pump temperature = 54 Permanent Histerezis = 14 Burner: Air min 20% = 30 Air max 100% = 45 Feeding administration max = 2.4 CO heating: Histerezis = 0.1 Weather curve = 60 / 53 / 46 Correction factor = 10 -
Dostałem to lepiej, redukując administrację z 2,6 do 2,4 s i zwiększając krzywe pogody o 4 stopnie wyższe. Teraz mam maksymalne przegrzanie do 76 - 80 stopni. Nie rozumiem, jak działa tryb AUTO w ustawieniach kotła? Czy liczy się histereza i start pompy? -
Tak -
nie, pompa działa, pomieszczenie temperatury jeszcze nie zostało osiągnięte -
jak zmniejszyć przegrzewanie? i nadal utrzymywać wzrost temperatury na kotle? tekla bio draco 12, zawór 4d, dobrze wykonana instalacja z zaworem 5/4 i rurą o średnicy 35 mm między zaworem i powrotem kotła ustawienia kotła: ręcznie temp ustawiono na 65 stopni, hist 10 stopni pompy min. temp. 55 ustawienia centralnego ogrzewania: krzywa -20 0 +10 = 50 46 39 współczynnik korekcji 10 stopni ustawienia palnika obliczenie ważonej próby pelletu = 22 kg na godzinę zmniejszyłem maksymalną administrację z 3 do 2.6, aby utrzymać przegrzanie pod kontrolą, ale teraz trudno jest osiągnąć temperaturę zadaną kotła. oscyluje w 59 przez godzinę, a następnie nagle przegrzewa do 85 90 Mam videnet, mogę dodać twoje nazwy użytkownika -
ktoś tu z teklą i pracującym zaworem mieszającym 4d? jaki jest maksymalny czas otwarcia zaworu na sterowniku? -
w przypadku zaworu mieszającego 4d do pracy z termosyfonem jego najniższa część powinna znajdować się wyżej niż wyjście zasilania kotła. potrzebuje również dużej średnicy rury między nim a zasilaniem i powrotem kotła. Przykładowo średnica 5/4 cala dla 10 kW kotła. zawór mieszający powinien również wynosić 5/4 la 10kw. 35kw potrzebuje bardzo dużych średnic, więc pompa powrotna naprawi to przy niższych średnicach. -
https://forum.info-ogrzewanie.pl/topic/19634-opinie-na-temat-tekla-draco-bio-tekla-draco-bio-compact-12-kw/page-35 Post #690 -
jak zimny jest powrót rano? mniej niż 50? może nie masz wystarczająco grawitacyjnego termosyfonowania na 4d. jaka średnica rury znajduje się wyżej niż rura wylotowa kotła? -
to smutne z estymą. może można to zrobić, sprawiając, że sterownik otwiera 4d wolniej? lub zacznij od wyższej temperatury na zasilaniu kotła przed otwarciem zaworu 4d? -
za pomocą prostego termometru na powrocie kotła można go obejrzeć i ustawić temperaturę CO CO w sterowniku estyma, tak aby powrót wynosił 55 stopni C na termometrze powrotnym -
jakie masz spalanie pelletu w kg na dzień? -
OK, w końcu zdecydowałem, że odeślę 4d zmotoryzowany zawór i kupię 3d zmotoryzowany zawór, a ja również użyję pompy obejściowej w pobliżu kotła. Podobnie jak na schemacie poniżej. Miałem objawienie! Widzę, że Estyma Igneo nigdy nie wyznaczył swojego regulatora do pracy z 4-drogowymi zaworami (patrz: atach, tylko symbole 3d, nigdy 4d). OK, in the end I decided to send a 4d motorized valve and buy a 3d motorized valve, and I will also use a bypass pump near the boiler. Similar to the diagram below. I had a revelation! I see that Estyma Igneo has never set its regulator to work with 4-way valves (see ATA, only 3d symbols, never 4d). -
dzięki. w twoim schemacie jest zawór 3d z napędem lub termostatyczny? Problem polega na tym, że już zamówiłem zawór 4d zmotoryzowany. Czy mogę ustawić priotiy dla tego, aby chronić powrót do 60 stopni zamiast zapewniać komfort domowy?
