Treść opublikowana przez Paollo
- Opinie Na Temat Tekla Draco Bio / Tekla Draco Bio Compact 12 Kw
friends, what actuator motor do you use for your 4D valve? I have one with 120s (supplier recomandation). But I feel I need one with 240s because at pump start the hot water goes too fast in radiators and the temperature jumps above the set IC with even 6 degrees above the set temperature. The return gets cold, and the pump stop.
Increase the source in the CH settings (standard is 10 I think and maximum is 30). It decreases because of 2 reasons: Correction factor is set to high. Lower it. Return protection setting is on - and that lowers the CH temperature gradually until the return temperature that is set in your settings is achieved. After that is increasing again. My opinion, not necessary the best.
Dracogo can you share your settings please? 1. Do you work with stove in Auto mode even in winter? 2. Do you work with permanent pump on CH? 3. What is your pump start temperature? 4. For exemple I would increase my pump start temperature. I can not go higher than 60-hysteresis or 60-5 = 55
The instalation is not good enough. The termosiphon may not work for you. You need more pipes between 4d and also bigger 4d valve. But a simple fix would like to add a bypass pump between 4d and stove return, cut that vertical pipe. Bypass pump + CH pump should be connected on the same connector, in parallel.
Agree. That is what I did this morning. Already works better but not enough. Boiler manual 64 C Both histerezis are now at 5 but I will increase them to see what happens. CH: increased heating curves by 3 degrees on average Burner: I increased incandescing power from 35% to 50% to give more initial power
Thanks. I managed to improve it by lowering the CH Corection factor. I reduced it from 7C to 2C so that are less variations on the demand of instalation. I also reduced the burner feeding / administration from 3.0s to 2.8s and obiously reduced the ventilator curves accordingly. my settings: burner: power 30%-100% Maximum feeding 2.8 ventilator 30-45 TEst measured pellet: 20kg/hr boiler: auto 60 C Start histerezis 0 C stop histerezis 5 C pump min temperature 53 pump overrun 12min CH: histerezis 0.2 weather work 45 C, 41 C, 36 C increase source temperature 23 C max temp 45 C correction factor 2 C CH lowering 7 C pump constant return protection no
I made some masurements and been able to plot an exact chart for the actual power of the burner in percentage. And corelated with the videnet temperature. My problem is the same as everybody’s. The burner cannot modulate well and estinguishes before reaching the room temperature set. Igneo touch+big mdoul 4d valve Stove: auto mode, 60 degrees Any ideas? Please respond to me in Polish, I will understand.
przyjaciele, jeśli twój kocioł nie może wejść do ustawionej temperatury, musisz zmienić ją na palnik: 1. Zwiększ minimalną moc o więcej niż 30%. Rozwiązał mnie, gdy ustawiłem 50%. 2. Obniżyłem bezwładność palnika z 5 minut do 2 minut (opcjonalnie, wymaga to technicznego kodu i przechodzi tylko do igneo touch). dla kotła: mod: auto, Histereza uruchamiania: 0 stop histerezy: 4 (opcjonalnie, tylko igneo touch) Uruchamianie pomp: 50 stopni do ciepłej wody użytkowej: Temperatury należy zwiększać w miarę możliwości. Mam bufor ciepłej wody o pojemności 200 litrów. 1. Źródło DELTA: 14 stopni. 2. pompa rozrusznika: 14 stopni do ogrzewania chłodnicy: Mam zawór 4D. Mam 8 grzejników i 100 m powierzchni pompa: stała krzywe grzania: +10, 0, -25: 30, 37, 45 stopni współczynnik korekcji: 10 stopni zwiększyć źródło temperatury o 30 stopni (tylko igneo touch) jeśli chcesz więcej pomocy, napisz tutaj wszystkie twoje ustawienia i rodzaj instalacji i powierzchni, które masz
Dokładnie. FL3 spodziewa się działać zgodnie z zapotrzebowaniem na ciepło. Dla trybu automatycznego działa źle: Jeśli zapotrzebowanie na ciepło jest niskie do momentu uruchomienia pomp, to będzie działać przez 30% do 40% przez długi czas, aż osiągnie 50 stopni (moja minimalna temperatura pracy pompy). Następnie pompy włączają się i wyłączają kilka razy. Powrót jest zimny i inne problemy. Moim rozwiązaniem było zwiększenie minimalnej mocy do 40% i zamierzam ją zwiększyć do 50%. Działa lepiej w trybie ręcznym ze stałą temperaturą 60 stopni C (jesień i wiosna) i 65-70 stopni C zimą.
witaj teklahubert. Mam te same narzekania co ty. Modulacja FL zwiększa moc zbyt wolno, ale problem pochodzi z: 1. małą powierzchnię musimy ogrzać, moje jest tylko 100 m 2. użycie pompy stałej ze względu na ogrzewanie podłogowe w twoim przypadku, a także małe temperatury w grzejnikach od 30 do 45 stopni C spróbuj ręcznego trybu pracy kotła nieautomatycznego. również zapisz wszystkie swoje ustawienia
- Sterownik Estyma Igneo Slim, Opinie, Problemy, Lista Życzeń I Co Jest Dobre.
