Paollo
Treść opublikowana przez Paollo
Paollo odpowiedział(a) na Sterydziak temat w Kotły pelletowe
friends, what actuator motor do you use for your 4D valve? I have one with 120s (supplier recomandation). But I feel I need one with 240s because at pump start the hot water goes too fast in radiators and the temperature jumps above the set IC with even 6 degrees above the set temperature. The return gets cold, and the pump stop. -
Increase the source in the CH settings (standard is 10 I think and maximum is 30). It decreases because of 2 reasons: Correction factor is set to high. Lower it. Return protection setting is on - and that lowers the CH temperature gradually until the return temperature that is set in your settings is achieved. After that is increasing again. My opinion, not necessary the best. -
Your stepped settings look like a modulation. Very well indeed, and I know how you have a very low consumption of pellets(compared to the house you are heating). But I have Touch. -
It looks nice. The first time I'm seeing a 4d tekla that can modulate well from start to finish. -
Dracogo can you share your settings please? 1. Do you work with stove in Auto mode even in winter? 2. Do you work with permanent pump on CH? 3. What is your pump start temperature? 4. For exemple I would increase my pump start temperature. I can not go higher than 60-hysteresis or 60-5 = 55 -
It calculates 60 because of the return protection wich lowers the temperature. -
5/4 is at the limit. I also have 5/4 but I have tekla 12 and I have a small house. Try with the settings may you can make it work without aditional instalation changes. -
The instalation is not good enough. The termosiphon may not work for you. You need more pipes between 4d and also bigger 4d valve. But a simple fix would like to add a bypass pump between 4d and stove return, cut that vertical pipe. Bypass pump + CH pump should be connected on the same connector, in parallel. -
Increase the source temperature in the CH menu from 10 to 20 or more. I have 24. Only with igneo touch works. And reduce the correction factor from 10 to 3. Also you can lower the heating curve with 5 degrees. Can i see photos of your 4d instalation? -
Agree. That is what I did this morning. Already works better but not enough. Boiler manual 64 C Both histerezis are now at 5 but I will increase them to see what happens. CH: increased heating curves by 3 degrees on average Burner: I increased incandescing power from 35% to 50% to give more initial power -
Maybe can you give some ideas on where to start? -
Thanks. I managed to improve it by lowering the CH Corection factor. I reduced it from 7C to 2C so that are less variations on the demand of instalation. I also reduced the burner feeding / administration from 3.0s to 2.8s and obiously reduced the ventilator curves accordingly. my settings: burner: power 30%-100% Maximum feeding 2.8 ventilator 30-45 TEst measured pellet: 20kg/hr boiler: auto 60 C Start histerezis 0 C stop histerezis 5 C pump min temperature 53 pump overrun 12min CH: histerezis 0.2 weather work 45 C, 41 C, 36 C increase source temperature 23 C max temp 45 C correction factor 2 C CH lowering 7 C pump constant return protection no -
I made some masurements and been able to plot an exact chart for the actual power of the burner in percentage. And corelated with the videnet temperature. My problem is the same as everybody’s. The burner cannot modulate well and estinguishes before reaching the room temperature set. Igneo touch+big mdoul 4d valve Stove: auto mode, 60 degrees Any ideas? Please respond to me in Polish, I will understand. -
Anyone else who has the Videnet getting the message “error” from time to time? Sometimes also “offline” but that is normal. -
przyjaciele, jeśli twój kocioł nie może wejść do ustawionej temperatury, musisz zmienić ją na palnik: 1. Zwiększ minimalną moc o więcej niż 30%. Rozwiązał mnie, gdy ustawiłem 50%. 2. Obniżyłem bezwładność palnika z 5 minut do 2 minut (opcjonalnie, wymaga to technicznego kodu i przechodzi tylko do igneo touch). dla kotła: mod: auto, Histereza uruchamiania: 0 stop histerezy: 4 (opcjonalnie, tylko igneo touch) Uruchamianie pomp: 50 stopni do ciepłej wody użytkowej: Temperatury należy zwiększać w miarę możliwości. Mam bufor ciepłej wody o pojemności 200 litrów. 1. Źródło DELTA: 14 stopni. 2. pompa rozrusznika: 14 stopni do ogrzewania chłodnicy: Mam zawór 4D. Mam 8 grzejników i 100 m powierzchni pompa: stała krzywe grzania: +10, 0, -25: 30, 37, 45 stopni współczynnik korekcji: 10 stopni zwiększyć źródło temperatury o 30 stopni (tylko igneo touch) jeśli chcesz więcej pomocy, napisz tutaj wszystkie twoje ustawienia i rodzaj instalacji i powierzchni, które masz -
What PIN do you use so you can accesss the reaction time of the burner? i only know about 0900 -
Czy masz teraz tryb automatyczny lub ręczny? Mam auto i ustawiam źródło ogrzewania w grzejnikach na maksimum: 30 stopni. Tak więc dla 35 stopni w grzejnikach (mam stałą pompę) oblicza mnie 65 stopni na początek, a następnie powoli spada do 60 stopni. -
Dokładnie. FL3 spodziewa się działać zgodnie z zapotrzebowaniem na ciepło. Dla trybu automatycznego działa źle: Jeśli zapotrzebowanie na ciepło jest niskie do momentu uruchomienia pomp, to będzie działać przez 30% do 40% przez długi czas, aż osiągnie 50 stopni (moja minimalna temperatura pracy pompy). Następnie pompy włączają się i wyłączają kilka razy. Powrót jest zimny i inne problemy. Moim rozwiązaniem było zwiększenie minimalnej mocy do 40% i zamierzam ją zwiększyć do 50%. Działa lepiej w trybie ręcznym ze stałą temperaturą 60 stopni C (jesień i wiosna) i 65-70 stopni C zimą. -
witaj teklahubert. Mam te same narzekania co ty. Modulacja FL zwiększa moc zbyt wolno, ale problem pochodzi z: 1. małą powierzchnię musimy ogrzać, moje jest tylko 100 m 2. użycie pompy stałej ze względu na ogrzewanie podłogowe w twoim przypadku, a także małe temperatury w grzejnikach od 30 do 45 stopni C spróbuj ręcznego trybu pracy kotła nieautomatycznego. również zapisz wszystkie swoje ustawienia -
Witam, ktoś wie gdzie mogę kupić moduł Estyma Igneo CAN I / O BIG? Mam już ekran dotykowy Igneo Touch.
I added Igneo Touch and I can edit the heating time programs in IGNEO VIDENET . There is a button in the Heating section. -
Delete your device in igneo.pl and add it again. -
I talked to Estyma. They are very kind. For my CAN IO module i had to put in8 to Gnd. And i moved the return sensor from 39 to 40. -
zaktualizowałem do igneo touch. ale zachowałem moduł fabryczny CAN IO. palnik jest zablokowany czerwoną blokadą i nie uruchamia się bez względu na ustawienia, których używam. -
