north
Treść opublikowana przez north
north odpowiedział(a) na track33 temat w Kotły zasypowe
Modlę się za link i izolacją ceramiczną thanks- 1787 odpowiedzi
- Dobór mocy kotła
- Kocioł węglowy
- (i 10 więcej)
niech Probat jak to zostanie przetłumaczone, jeśli jest to zrozumiałe, będziemy pisać- 1787 odpowiedzi
- Dobór mocy kotła
- Kocioł węglowy
- (i 10 więcej)
good boilers but these are to work outside the house kunzel :rolleyes: this is too much for my budget I love the idea that the boiler and tank is a single continent, because there is no loss ,boiler itself is half pyrolysis. as said gondoljerzy I also want to use a variety of fuel because you never know what will be the cheapest at present time- 1787 odpowiedzi
- Dobór mocy kotła
- Kocioł węglowy
- (i 10 więcej)
as I said this is just a temporary solution when I find a cheap gas tank I will build something like this http://garn.com/- 1787 odpowiedzi
- Dobór mocy kotła
- Kocioł węglowy
- (i 10 więcej)
greeting I also read this forum but I have not seen this picture :wub: :wub: interesting solution for short passage of flue gases vermiculite got home and there is no problem for chamber casting phenomenal solutions give a new perspective on the possibility of recovery boiler I love the simplicity of the boiler I would like to work with electronics reduced to a minimum because it is possible pyrolysis-establish the natural way I owe you a drink :D :D- 1787 odpowiedzi
- Dobór mocy kotła
- Kocioł węglowy
- (i 10 więcej)
boiler hawe heavy chamber nearly 300 kg this is the studio dr. hill http://hotandcold.tv/wood% 20furnace.html who built this boiler and can account as a precursor to modern boilers pyrolysis ps: I'm trying to get it to read Polish and i can understand 40% of that our languages are not very different- 1787 odpowiedzi
- Dobór mocy kotła
- Kocioł węglowy
- (i 10 więcej)
no problem for English read the problem I have with the writing I slept grammar lesson at school I know the issue with pyrolysis I much deal with this and I am also able to start the mower motor on wood gas, I love the simplicity of this boiler http://books.google.hr/books?id=hs8DAAAAMBAJ&pg=PA20&lpg=PA20&dq=madawaska+wood+furnace+company&source=bl&ots=p8LfaWgIBB&sig=ZAZiMDQzQvMpDzJIm9rsjczFtLc&hl=en&ei=2Y4-TZO9LIGBlAftgqihAw&sa=X&oi=book_result&ct=result&redir_esc=y#v=onepage&q&f=false- 1787 odpowiedzi
- Dobór mocy kotła
- Kocioł węglowy
- (i 10 więcej)
I also use tertiary air, but I see that it is not enough sekundar air inside the chamber when I use compressor and add it directly into the chamber I have a clean blue flame(otherwise I have a blue flame just is not as intense as I wanted) on the exchangers is only a fine powder and this just blew the with compressor. tar is only in the loading chamber problem processing this boiler to pyrolysis is only in that when i puth chamber in I can not light the boilr without suction fan,because I have no way to do a short passage of flue gases for start it . connected is to the 1000l tank with integrated 150l boilerjem for domestic water This boiler is a transitional option for now because I bought a cheap (300E three years old) ps: Sorry to poor English- 1787 odpowiedzi
- Dobór mocy kotła
- Kocioł węglowy
- (i 10 więcej)
przemyslaw2ar greeting I read all about making your boiler and you have my respect I know that flue gases do not like shared channels but my improvisation was fast and what I had on hand My wish is to pour the right chamber for pyrolysis because the boiler has enough space when extracted gratings- 1787 odpowiedzi
- Dobór mocy kotła
- Kocioł węglowy
- (i 10 więcej)
gondoljerzy jes is junkers supraclas or dakon dor d 28 KW for wood in Figure 4 is removed bricks that can be seen secondary air,This is the brake for better combustion because it does not get enough air in a chamber with no direct supply from outside boiler , tercial air su high ,turbulator for the third channel was made quickly with what I had at hand, yeah you're right melting point of NaCl is 801C I forgot to write that it was after the salt in boiler, copper which has a melting point at 1080C and melts only edges- 1787 odpowiedzi
- Dobór mocy kotła
- Kocioł węglowy
- (i 10 więcej)
- 1787 odpowiedzi
- Dobór mocy kotła
- Kocioł węglowy
- (i 10 więcej)
temperature in my primitive pyrolysis chamber is around 950 degrees tested is with salt, salt melts at 900 C- 1787 odpowiedzi
- Dobór mocy kotła
- Kocioł węglowy
- (i 10 więcej)
- 1787 odpowiedzi
- Dobór mocy kotła
- Kocioł węglowy
- (i 10 więcej)
- 1787 odpowiedzi
- Dobór mocy kotła
- Kocioł węglowy
- (i 10 więcej)
I used modifications from kaz (I was forced to because the third grid vas melt l) i burn only wood Here is a picture of what's left of the grid http://www.mediafire.com/imgbnc.php/4c8729aab1556281481f42b5c1d8b88655d99f2542d31e7a6ad90100e8de96266g.jpg now wood burn with no problem even when it starts to burn no more smoke in the boiler room- 1787 odpowiedzi
- Dobór mocy kotła
- Kocioł węglowy
- (i 10 więcej)
Merry Christmas to all good people- 1787 odpowiedzi
- Dobór mocy kotła
- Kocioł węglowy
- (i 10 więcej)
Hai Kaz what type of boiler do you have What are the basic fuel- 1787 odpowiedzi
- Dobór mocy kotła
- Kocioł węglowy
- (i 10 więcej)
I am burning the wood question How do you regulate the temperature of flue gases because they can be very high up tu 350C If I put the regulator on the less I stopped burning anyone have any idea- 1787 odpowiedzi
- Dobór mocy kotła
- Kocioł węglowy
- (i 10 więcej)
hai What no one has any more problems with our boiler :rolleyes: :rolleyes: :rolleyes: :rolleyes:- 1787 odpowiedzi
- Dobór mocy kotła
- Kocioł węglowy
- (i 10 więcej)
hai I agree with similar characteristics but lacks the flue gas sensor and the ability to connect to a computer (SPR-10 instructions are in Polish language and I was a bit difficult to understand if these two options are included, if thej are then this is a controler for me) my basic fuel wood is because it is very difficult for us to purchase quality coal (heck I live in the middle of Europe in Banana Republic) this is my main purpose for me is the controller in the appropriate solution for my future boiler room if you have any more guidance welcome- 1787 odpowiedzi
- Dobór mocy kotła
- Kocioł węglowy
- (i 10 więcej)
I understand that each controller to precisely match the fan speed can be controlled burning but I would like controller that will manage all combustion, heat-buffer. pumps. grating (motorized) I found on the internet that cost around 500 zloty in my country would cost twice as much if you have any better and cheaper idea is recommended for advice Thanks in advance- 1787 odpowiedzi
- Dobór mocy kotła
- Kocioł węglowy
- (i 10 więcej)
hai I would favor anyone could help me I'd like to buy a controller Ecomax 200 W produced by http://www.plum.pl/en/?id=192 do not respond to e mail if anyone would want to call and ask how much the cost with all sensors ps: I apologize for the language Direct contact saso.sever @ inet.hr- 1787 odpowiedzi
- Dobór mocy kotła
- Kocioł węglowy
- (i 10 więcej)
All I read about dakon dor-Junkers in this forum and in this http://www.energoportal.cz most are faced with the problem of smoke and fire control great respect for Mr. quitar, and its innovation which I put to good use on my boiler supraclas 32d I plan to put a similar fan in the smoke pipe like this http://www.draftinducers.com/ad1.htm I plan mainly burn wood because it is difficult for us buy quality choal the stove will be connected to the tank through laddomat21 1000l I warmed some medium-insulated house 100m2 question You used auraton 1111 is he smart enough to steer it all that any advice is welcome- 1787 odpowiedzi
- Dobór mocy kotła
- Kocioł węglowy
- (i 10 więcej)
hai I understand the benefits of the fan pushing air into the furnace for now i burned remains of charcoal powder granules 0-12mm (not in supraclas) with the help of a fan mounted on the door as an oil burner but they also know the weaknesses of this system exhaust fan seems to me a better idea because is possible to avoid the smoke in the boiler room- 1787 odpowiedzi
- Dobór mocy kotła
- Kocioł węglowy
- (i 10 więcej)
you do not understand me i think the fan that was mounted at the exit from the furnace flue- 1787 odpowiedzi
- Dobór mocy kotła
- Kocioł węglowy
- (i 10 więcej)
