WITAM. CZYTAM TE FORUM OD ROKU I WIOSNĄ KUPIŁEM PIEC Z PODAJNIKIEM TŁOKOWYM NA MIAŁ Z FIRMY STAL-MET KOŁO ANDRYCHOWA. JEST TO PIEC ZROBIONY NA WZÓR STALMARKA ALE CZYTAJĄC FORUM I WASZE PROBLEMY UWAŻAM ŻE MÓJ JEST TROCHĘ LEPIEJ ZROBIONY PONIEWAŻ MA NISKĄ KOMORĘ SPALANIA I MOŻE DLATEGO MNIEJ SADZY I CZYSTY DACH. PO PRZECZYTANIU WSZYSTKICH POSTÓW POBAWIŁEM SIĘ Z MOIM PIECYKIEM I NASTAWIŁEM WENTYLATOR Z USTAWIONEGO MAXIMUM CZYLI 6 NA 4 I EFEKT WIDOCZNY GOŁYM OKIEM ZUŻYCIE 30KG MIAŁU (Z KOPALNI BOBREK ZA 420ZŁ TONA) NA DOBĘ PRZY TEMP -10 NA ZEWNĄTRZ A Z KOMINA BIAŁY DYMEK JAK Z GAZÓWKI.
DODAM ZE MAM STEROWNIK RK-30 USTAWIONY TAK:
PODAWANIE 5SEKUND
PRZERWA 2.15
NADMUCH 4 Z 6 MOŻLIWYCH
TEMPERATURA ZADANA 60 STOPNI
